#7946 - 11/10/06 11:39 AM Gridview Backups
bal Offline
Adagio Ace
Loc: Ottawa
it usually takes me quite a while to prepare my Gridviews. I have discovered a neat trick for backing up my Gridviews when I do my daily accounting data backup.
I save the Gridview file as FileName.gv.bio to the accounting data folder.
Then when I "Backup-Complete Dataset" in my GL the gridviews are included in the backups.
If you want to open the files from the File-Open, you must remember to look at "all files". (The default is .gv)
#7951 - 11/10/06 07:50 PM Re: Gridview Backups [Re: bal]
That is not a recommended approach, in my opinion (although quite creative). The downside is that you can only include in Workspaces views that have an extension of .gv.
Why not just write a batch file that backs up your .gv* files and create a shortcut on your desktop that launches the batch file?
#7954 - 11/11/06 10:59 AM Re: Gridview Backups [Re: bal]
Hi Bal,
If you name your General Ledger Views GL*.gv, then they will be backed up whenever you backup your general ledger files.
#7961 - 11/14/06 10:32 AM Re: Gridview Backups [Re: Retired_Guy]
bal Offline
Adagio Ace
Loc: Ottawa
Does the Softrak backup pick up on the initial leeters of the filename ("GL", "AP", "AR") or the extension (.bio)?
Thanks.
#7962 - 11/14/06 10:36 AM Re: Gridview Backups [Re: bal]
Hi bal,
If you backup the module you are working in (or related modules), then the first letter wildcard is used (GL*.dat). If you back up all modules, then all files matching the extension are chosen (*.dat).
