Previous Thread
Next Thread
Print Thread
#71939 08/13/25 03:32 PM
If you switching from TelPay for Business to TelPay Online then remove the "Startup program" from your EFT Provider setup.
You could also change the "Payment Folder" location so that you didn't have to drill down so many layers to find it.
Adagio will still create the Payment file as required and will stop launching TelPay for Business which is not required for Telpay Online.
(Softrak, I originally sent this directly to Support but then decided it would be appropriate to update my original post for all dealers to see)
Further to this post I've converted AccSys Solutions from Telpay for Business to Telpay Online and discovered another issue to be aware of:
As Telpay is starting to encourage the Adagio users of Telpay for Business to convert to Telpay Online we really need a different solution for the output file name and location.
Telpay for Business creates X:\Billpay\Telpay\XXXXXXX\TAPIMP\NAP 460.###
Telpay Online requires a CSV file (no layout change) and would be better served to just use the EFT Provider Payment folder with just the Access code added as a subfolder, for example X:\AccSysData\EFT\XXXXXXX\NAP ###.CSV
Where XXXXXXX is the Access code and ### is the sequence number.
Until Softrak releases an update you can manually change the file name from NAP 460.### to NAP ###.CSV
BTW: The 460 in the file name is the Payment type, 460 Accounts Payable
Hello Doug,
In the Payables 9.3C (20251117) Service Pack, the EFT Batch Format for TelPay has been updated with an option for TelPay Online.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 77 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
