#71988 - 09/11/25 03:36 PM AR error message
JeanB Offline
Loc: Kelowna, BC
I'm trying to run a Customer Transactions report in AR but when I click on the report name in the dropdown the following error message pops up:
Unable to open data file GL fiscal years @L90AFYE, (1213)
When I click on the OK button I get this error:
Attempting to perform operation on unopened GL fiscal years file
At this point the program freezes and I have to force close it.
It's only happening with one of our subledger datasets, the other one seems to run fine. What's causing it and how do I fix it? It's never happened before...
Edited by JeanB (09/11/25 03:42 PM)
#71989 - 09/12/25 07:19 AM Re: AR error message [Re: JeanB]
Hello Jean,
You haven't given any version information. Receivables should be 9.3B (250324) Service Pack and Ledger should be 9.3B (231109) Service Pack.
Can you access Ledger data using the current version of Ledger for this dataset?
#71990 - 09/12/25 10:39 AM Re: AR error message [Re: Softrak Support]
JeanB Offline
Loc: Kelowna, BC
We're using A/R 9.3B(230215) and GL 9.3B(230518).
We use the same versions for both databases and one data set works fine but the other gives the error.
The error only pops up when trying to run the Customer Transactions report.
Edited by JeanB (09/12/25 10:45 AM)
#71991 - 09/12/25 11:05 AM Re: AR error message [Re: JeanB]
Hello Jean,
You should contact your Adagio Consultant.
You do not have the latest Service Packs and you have not answered my question: Can you access Ledger data using the current version of Ledger for this dataset?
#71992 - 09/12/25 11:19 AM Re: AR error message [Re: Softrak Support]
JeanB Offline
Loc: Kelowna, BC
I can access everything (GL, AP, AR) and run every report using this dataset... except for the Customer Transactions report.
Edited by JeanB (09/12/25 11:22 AM)
#71993 - 09/12/25 11:22 AM Re: AR error message [Re: JeanB]
You need to contact your Adagio Consultant.
#71994 - 09/12/25 12:22 PM Re: AR error message [Re: Steve Schwartz]
JeanB Offline
Loc: Kelowna, BC
Okay thanks
#71995 - 09/12/25 12:23 PM Re: AR error message [Re: Steve Schwartz]
Hello Jean,
That is good information. You still need to install the current Service Packs.
You should also check for a ModifiedReports folder in the Receivables program folder and remove it.
#71996 - 09/12/25 01:13 PM Re: AR error message [Re: Softrak Support]
JeanB Offline
Loc: Kelowna, BC
Thanks. I'll have our tech person do the installs next week and see if that fixes the issue.
There was no Modified Reports folder so that's not causing the problem.
#71997 - 09/15/25 05:04 AM Re: AR error message [Re: JeanB]
chinmook Offline
Edward Chris Chin-Mook
Loc: Jamaica
Hi JeanB,
Does the error occur for (ALL) customers or a specific Customer (check name only letters and numbers no characters) ?
If you open (AR) Sample Data and attempt the same report does it work or not ?
?:\Softrak\Receivables\SAMDATA
If later works run (DIC)
Also make sure IT Department does a re-start on the server so no open or lock files..
You and I may be having the same (Managed IT) Department limitations.... I keep my sanity by having an in house mirror server to simulate a "Perfect Working Environment" because when the CLIENT Server Operating System starts to act up, you will think Ghosts are in the ADAGIO System.
Also what is your install configuration - a) Traditional - Client / Server or b) RDP Server Virtualization.
I can bet you do not have a REAL problem, but a SERVER issue...because others consultants would be screaming long before you..
Edward C Chin-Mook
876-754-7444
876-754-5513
0 registered (), 101 Guests and 1 Spider online.
14625 Topics
