#66628 - 07/26/21 01:29 PM Re: Attach PDF, A/P Import [Re: Holiday]
The "Copying to storage..." error indicates a problem with DocStore - not the import. Run a DIC on DocStore.
#66629 - 07/26/21 01:30 PM Re: Attach PDF, A/P Import [Re: Holiday]
Holiday Offline
Hi again,
Just tried using a back slash in the second location as well, and it worked!
Thanks very much for your help on this.
#66630 - 07/26/21 01:37 PM Re: Attach PDF, A/P Import [Re: Holiday]
One small change at a time... I am glad it is working!
Happy Monday!
#68831 - 10/24/22 03:54 PM Re: Attach PDF, A/P Import [Re: Softrak Support]
Hi Support:
I have a similar issue in GL. The path to the data is created by GV with multiple forward slashes "/" instead of "\". Unfortunately, the import gives me the same error message with trying to import using the "/". I tested it changing it manually in the import file and it works. Is there any setting that tells Adagio to use one or the other?
#68834 - 10/25/22 08:18 AM Re: Attach PDF, A/P Import [Re: Patricia B.]
Hello Patricia,
No, there is no setting in Adagio or Gridview that controls whether the path has back or forward slashes.
