Posts: 10,504 |
The "Copying to storage..." error indicates a problem with DocStore - not the import. Run a DIC on DocStore.
Posts: 103 |
Hi again,
Just tried using a back slash in the second location as well, and it worked!
Thanks very much for your help on this.
Posts: 11,747 |
One small change at a time... I am glad it is working!
Happy Monday!
Regards, Softrak Tech Support
Posts: 1,211 |
Hi Support:
I have a similar issue in GL. The path to the data is created by GV with multiple forward slashes "/" instead of "\". Unfortunately, the import gives me the same error message with trying to import using the "/". I tested it changing it manually in the import file and it works. Is there any setting that tells Adagio to use one or the other?
Posts: 11,747 |
Hello Patricia,
No, there is no setting in Adagio or Gridview that controls whether the path has back or forward slashes.
Forums5
Topics14,679
Posts71,626
Members1,874
S |
M |
T |
W |
T |
F |
S |
