#65917 - 04/07/21 11:02 AM Error Message - AP 9.3B(200811)
Paul_L Offline
Casual
Loc: Ottawa, Ontario, Canada
Tring to create an EFT and getting the following message "Error 4104 occurred when attempting to append record to Temp Precheck Register" Did data check and it created multiple errors which have been rebuilt but still getting same issue. Any suggestions?
#65918 - 04/07/21 11:13 AM Re: Error Message - AP 9.3B(200811) [Re: Paul_L]
Bob Wisener Offline
Adagio Conductor
You could try manually deleting your temp precheck files. I'm assuming, you don't have some other check run in progress. AP will recreate them on startup. There are two files: APTRUN'I and APTRUN'R in your data folder. If that doesn't solve the problem, it's likely the EFT process writing the records to that file.
Bob Wisener
Dakota Software
#65919 - 04/07/21 11:26 AM Re: Error Message - AP 9.3B(200811) [Re: Bob Wisener]
Paul_L Offline
Casual
That did the trick! Thanks!
1 registered (1 invisible), 228 Guests and 3 Spiders online.
14672 Topics
