#63423 - 03/22/20 12:13 PM
Financial Reporter won't open
Bob Stewart
Loc: Thunder Bay, ON, Canada
New development... Never had this issue before. Went to open the financial reporter in Adagio Ledger. It appears to start, but closes down on it's own. I've logged out and back in, no change. I've done a complete reboot, no change. Not sure where the issue has come from, could be a Windows 10 update??
#63424 - 03/22/20 01:55 PM
Re: Financial Reporter won't open
[Re: BTS]
Hi Bob,
Do you or did you have multiple screens connected to your PC? Do you actually see it completely open to a blank report or does it just not show up on your screen even though the toolbar button becomes grayed out?
#63431 - 03/23/20 06:28 AM
[Re: Dan_Desautels]
Adagio Padawan
Loc: Waterloo, ON
Hi Bob,
We've run into something similar to this with a couple of our clients. Do you have a long department group in your department list? There is a known bug in the current version of GL/FR, that if you exit with a department list enabled that has a lot of departments it won't open the next time. I'm not sure what the cut off is for number of departments, but our client's department groups that had this issue are in the dozens.
Create a new user with the same permissions as your old user, can you get into the financial reporter? If so then your department list is likely causing the issue. Until a fix is released you will need to either disable the department selector or switch to a single department before closing the financial reporter.
Lauren
Lauren Stief Stief Group Adagio Solutions and Support 1-800-540-3164
#63449 - 03/24/20 06:54 AM
[Re: Dan_Desautels]
Bob Stewart
If I try to access print financial reports either from reports tab or maintenance/maintian Fin reports. Financial Reports starts and appears to open and then just disappears. Bob
#63450 - 03/24/20 06:57 AM
[Re: Lauren Stief]
Bob Stewart
Try creating a new user, same issue - financial report starts, blinks on screen and disappears. Bob
#63451 - 03/24/20 07:41 AM
[Re: BTS]
Hi Bob:
Further to earlier posts: -Is the "Financial" button greyed out when that happens? -How many Departments in your organization?
There have been somewhat similar situations where the problem was a damaged file. But before going in that direction, could you let us know the answers to those 2 questions?
#63452 - 03/24/20 07:53 AM
[Re: Bruce Gardner]
zaam.ca
Loc: Ontario
Bob, try this, go to \softrak\ledger\ from that computer and launch LedgerFinRep.exe. Does that work? This launches the 32-bit version of the Fin.Reporter as opposed to the 64-bit from Ledger if you are on the latest version. Does it make a difference?
Vickie Cegliastro zaam.ca 613-532-6229
#63456 - 03/25/20 12:12 PM
[Re: Jesse_Gilbert]
Jesse:
What happens with sample data? That will indicate whether it is a system problem or a specific database problem.
14567 Topics
