5 Corgis and Counting
Posts: 181 |
Hello, We did a test migration to a new server. The environment is an app server and the client machine is a terminal server, both on Windows 2012. We are using different drive mappings, from S to X, if that is relevant.
We copied the Softrak and Data folders to the new server, ran Allwkst.exe on the new client server and updated the drive mappings in the ini file. The client will be testing on Monday and, assuming all goes ok, will go live later next week.
All seems to be working but when we run Chksys, we get these errors:
========== Checking 32-bit (and higher) System Status ========== C:\WINDOWS\SYSTEM32\P2QRTSSI.DLL Version: [] *** Error: Needs: [3.7.2.259] C:\WINDOWS\CRYSTAL\U25DTS.DLL Date: [] *** Error: Needs: [06/21/1999] C:\WINDOWS\CRYSTAL\U25STORE.DLL Date: [] *** Error: Needs: [03/09/1997] C:\WINDOWS\CRYSTAL\U25TOTAL.DLL Date: [] *** Error: Needs: [03/09/1997] C:\WINDOWS\CRYSTAL\U2LBAR.DLL Date: [] *** Error: Needs: [03/09/1997] C:\WINDOWS\CRYSTAL\U2LDTS.DLL Date: [] *** Error: Needs: [06/21/1999] C:\WINDOWS\CRYSTAL\U2LEXCH.DLL Date: [] *** Error: Needs: [06/21/1999] C:\WINDOWS\CRYSTAL\U2LFINRA.DLL Date: [] *** Error: Needs: [06/21/1999] C:\WINDOWS\CRYSTAL\U2LSAMP1.DLL Date: [] *** Error: Needs: [06/21/1999] C:\WINDOWS\CRYSTAL\P2IRSSI.CFG Date: [] *** Error: Needs: [02/14/2012] C:\WINDOWS\SYSTEM32\IMPLODE.DLL Date: [] *** Error: Needs: [02/15/1995] C:\WINDOWS\CRYSTAL\U252000.DLL Version: [] *** Error: Needs: [7.0.0.5] C:\WINDOWS\CRYSTAL\U2DDISK.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2DMAPI.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2DNOTES.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2DPOST.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2DVIM.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FCR.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FDIF.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FHTML.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FODBC.DLL Version: [] *** Error: Needs: [7.0.0.16] C:\WINDOWS\CRYSTAL\U2FRDEF.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FREC.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FRTF.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FSEPV.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FTEXT.DLL Version: [] *** Error: Needs: [8.5.0.66] C:\WINDOWS\CRYSTAL\U2FWKS.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FWORDW.DLL Version: [] *** Error: Needs: [7.0.100.0] C:\WINDOWS\CRYSTAL\U2FXLS.DLL Version: [] *** Error: Needs: [7.0.100.2] C:\WINDOWS\CRYSTAL\U2L2000.DLL Version: [] *** Error: Needs: [7.0.0.5] C:\WINDOWS\CRYSTAL\U2LCOM.DLL Version: [] *** Error: Needs: [7.0.100.0]
Reports print successfully to preview, but I'd like to resolve this before we go live.
Thanks in advance for any insights.
Regards, Carol O
Carol Lord Openhym Allegro Automation, Inc. Baltimore, MD USA
Posts: 11,746 |
Hi, Carol,
What's the version of the modules they are running? Do they have any pre-v9.2A modules installed?
Those are all files used by the older reporting model which changed for all v9.2A and higher modules.
If you/they don't need to print in any of the older modules still installed, the errors can be ignored. Or, if you do need to print, you could install the newest of their pre-v9.2A modules which should put them back. You'd want to copy the Windows\Crystal\p2irssi.cfg file from their old server to the new after.
Regards, Softrak Tech Support
Posts: 181 |
Hi there, Thanks for the reply. I do think they have an old APWIN in the folder, they're not using it so i think we should be ok. Many thanks as always!
0 members (),
71
guests, and
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
