#61976 - 10/01/19 07:48 AM did year end instead of period end
warkov Offline
New Guy
Loc: Winnipeg MB
Hi
is there anyway to tell if you accidentally did a year end instead of a period end?
and what to I do to fix it?
thank you in advance for your help.
best
K.G
#61977 - 10/01/19 08:10 AM Re: did year end instead of period end [Re: warkov]
You don't say which module, so I'll assume either Receivables or Payables.
To determine whether you ran Year End by accident, locate a very active Customer./Vendor, click on Edit (or View) then look at the "Statistics" tab. Look for the "YTD" figures. Check another Customer/Vendor. Are the YTD amounts zero? If so, you likely ran Year-End in error.
Another way to check is to click on the "Batch Inquiry" button on the main screen. If there are no batches listed, that also indicates that the Year-End was run.
If this just happened this morning, then you can restore your backup. But you should speak with your Adagio consultant first.
2 registered (Douglas Dickie, 1 invisible), 233 Guests and 2 Spiders online.
14672 Topics
