#61806 - 09/13/19 05:54 AM Separate by commas in Gridview
L10 Offline
Loc: Ontario
Looking for some advice:
I have a field in IC that holds multiple values separated by commas that I want to reference individually to another view. For example:
In IC:
Code:
{Comments 2}="2,3,40,45,73"
In Ref View:
Code:
2="A"
3="F"
40="ABC"
45="XYZ"
73="OOO"
I want to make the Gridview return
Code:
"A,F,ABC,XYZ,OOO"
While this sample is short the actual data is much more characters which is why I cannot fit it inside {Comments 2} example:
Code:
"mast:home,mast:commercial,primary:antenna,pimary:wireandcable,sub:cable,sub:coax"
Our thought is we would reference a number to each one of these tags.
Thanks in advance.
Lance Tennier
#61807 - 09/13/19 08:00 AM Re: Separate by commas in Gridview [Re: L10]
Hi Lance:
Each numeric tag matches to a specific text string?
Have you looked at the Named Item feature in GV? That would allow you to create a list that maps your tags to a text description (the tags could be letter rather than digits). You would use the function GETNAMEDITEM() to extract the text string.
GV formulas don't have a looping construct to handle a variable number of tags in a field. However look at the CHOOSE() function which will select a tag from a comma separated list.
I haven't tried this but I think it will work.
#61809 - 09/13/19 09:02 AM Re: Separate by commas in Gridview [Re: L10]
Hi Lance,
Just a comment about Bruce's "Named Item" suggestion.
These predate GridView's ability to read Excel spreadsheets and are certainly a reasonable suggestion for what you are trying to accomplish.
However, in my experience, I have replaced all my "Named Item" lists that I used historically with Excel spreadsheets that are loaded into Workspaces for reference. The Excel sheets are easier to maintain, and with the "File | New External" can be stored in a common Folder.
#61810 - 09/13/19 09:11 AM Re: Separate by commas in Gridview [Re: Retired_Guy]
Hi Andrew:
I considered that but I wasn't certain how that would work in this case. Lance has a "one-to-many" situation where a single IC Item would have to locate multiple rows in the lookup file (whether it be Excel or a Named Item). Can he do that using Excel as a linked table? I'm not even certain that a Named Item can do it because I haven't tried it, but I think so. smile
#61811 - 09/13/19 09:39 AM Re: Separate by commas in Gridview [Re: Bruce Gardner]
Hi Bruce,
Actually, Lance will want to use "TABLEFIND()" to look up the values in another View. It has the looping capability that I think is necessary here.
There is a description of the function in the F1-Help text and in the Release Note where it was added in 2014.
#61824 - 09/16/19 05:20 AM Re: Separate by commas in Gridview [Re: Retired_Guy]
L10 Offline
Loc: Ontario
Thanks Andrew,
I believe that is what I am looking for. I will give that a try.
Lance Tennier
0 registered (), 334 Guests and 2 Spiders online.
14625 Topics
