#59461 - 12/10/18 10:30 AM EFT Integration
Janet Offline
Adagio Graduate
Loc: Ontario
Wondering how I can retrieve EFT disbursements to the g/l as one amount to the bank as will show on my bank statement rather than the individual amounts that are posted to each vendor. Is this possible?
#59462 - 12/10/18 11:22 AM Re: EFT Integration [Re: Janet]
Hi Janet,
Are you doing a System Check run or Manual Check batches to create your EFT transactions?
There is a company profile option (System Options tab) for consolidating the Bank GL amounts to a single entry for System Check runs (whether or not EFT is used) called 'Post System Checks in Detail', which you would want to disable in order to get a single GL bank entry. The other side of the transactions would still be detailed for each vendor payment. And this option does not affect Manual check batch posting.
#59465 - 12/10/18 03:10 PM Re: EFT Integration [Re: Softrak Support]
Janet Offline
Adagio Graduate
Loc: Ontario
I did see this but if I still do some cheques I guess I would have to switch this back and forth?
#59468 - 12/10/18 05:29 PM Re: EFT Integration [Re: Janet]
Hi Janet,
There's an easy way to set this up using Adagio BankRec. Your Adagio Consultant can show you how this would work.
1 registered (Dan_Desautels), 236 Guests and 3 Spiders online.
14672 Topics
