#52463 - 01/30/17 09:29 AM Re: DIC hangs on Checking Invoice Batch [Re: Tammy]
Hi, Lars,
Tammy's suggestion is the correct workaround. With the information she provided to us Friday afternoon, we were able to determine the problem, which was a problem with DIC going into an endless loop not with conversion. The fix will go out with the next release.
In the meantime, if this site encounters the issue again, please have them do what Tam suggests.
So you know, in the data you sent, there were additional 'unrelated' DIC errors after and DIC does rebuild these.
#52478 - 01/30/17 07:02 PM Re: DIC hangs on Checking Invoice Batch [Re: Softrak Support]
Lars Offline
Loc: Vernon, B. C.
Hi all, Tammy's solution worked and looking forward to the fix - thank you!. I found those same 8 errors and were fixed with the Rebuild. Thanks for your help.
Lars Glimhagen
Adagio Certified Trainer
Email: lars@lng.bc.ca
#52528 - 02/01/17 04:54 PM Re: DIC hangs on Checking Invoice Batch [Re: Lars]
Integrity check has been fixed in the Payables 92B (170130) HF.
