#52422 - 01/25/17 10:12 AM
Toolbar disappears / Adagio doesn't work
5 Corgis and Counting
Loc: Baltimore, Maryland USA
This morning when my client logs into a company in Adagio from one workstation, the toolbar shows up as dim until the data loads. At this point, the toolbar disppears and the adagio desktop kind of has raised lines and no menu items work.
Other workstations are functioning.
Workstation OS Windows 10 Job Cost Version=9.2A (160126)
Get Adagio WS Info report is: Adagio Workstation Information [as of 1/25/2017 12:06:23 PM] Run from [G:\SOFTRAK]
User: [Grace] Logged into [\\GRACE-HP-Z230] as Admin. [True] with UAC Enabled [1] on Computer Name [GRACE-HP-Z230] Windows Version: [6.3.14393] Processor: [Intel64 Family 6 Model 60 Stepping 3, GenuineIntel]
Adagio Mapped drive: [G:]; UNC: [\\winserver\accounting];
=========================================================================== Adagio JobCost 6.8B (050114) === Company: [A&B Flooring Systems, Inc.] Wkst Version: Registry [20090633]; {must be >=} Main [20000101] Report Tables Status: Result is OK: [True]; {Is Eval. version: [False]} Report Tables drive: CU Registry [G:\]; CU UNC [\\winserver\accounting\]; LM Registry [G:\]; LM UNC [\\winserver\accounting\] Resources: Flags [CIXPW] Web storage Exe: [vitalEsafe.exe] Must update: [False]; Reg: [20110323] >= File: [20110323] {LM: [20110323] CU: [20110323]} PDF Must update: [False]; Reg: [20110510] >= File: [20110510] {LM: [20110510] CU: [--not checked--]} System Files: Components: [INST PRSTD PE85 PRGR] Terminal Server Files Status: {override to skip section: [], Y or empty} Windows folder [C:\Users\Grace\Windows\Crystal] Exists: [False]; (skip check if does not exist) QRW Status -- File: [G:\SOFTRAK\SYSTEM\QRASP\AJ\QRTAJW68.QRW] must exist: [False] ----- Registry Trace: ----- HK_CU: [Software\Softrak Systems] {Default:}; exists: [True];+Opened; . .Key: [vitalEsafeVersion] exists: [True] Value: [20110323] HK_LM: [Software\Softrak Systems] {Default:20110323}; exists: [True];+Opened; . .Key: [vitalEsafeVersion] exists: [True] Value: [20110323] HK_LM: [Software\Softrak Systems] {Default:}; exists: [True];+Opened; . .Key: [AdagioPDFVersion] exists: [True] Value: [20110510] ***** Adagio JobCost STATUS: WORKSTATION UPDATE REQUIRED. *****
I ran JC WS setup and that did nothing. I uninstalled and re-ran ALLWKST and that did nothing.
Anyone have any ideas?
Thanks, Carol
Carol Lord Openhym Allegro Automation, Inc. Baltimore, MD USA
#52424 - 01/25/17 11:45 AM
Re: Toolbar disappears / Adagio doesn't work
[Re: Softrak Support]
They are always close to if not current. Perhaps the old 6.8 is still on the server. I go out there about every 6 month and remotely work w/ them every couple of weeks. Other workstations are using the version
This workstation had been working until this morning. She had been in JC and AP on Monday and was off yesterday. FYI this is happening in AP too.
BTW Chksys.exe will not run. It is staying that i need to insert a disk for drive F to continue. Not sure what that's about since Adagio is on mapped Drive G and there isn't even a drive F.
Confused.
#52428 - 01/25/17 03:48 PM
I'll take a look at this tomorrow. Thanks for the suggestions.
#52434 - 01/26/17 09:24 AM
[Re: Carol Lord Openhym]
OK, when I run chksys from HER workstation I get the following message:
>> GLB2F7A.TMP - No Disk There is no disk in the drive. Please insert a disk into Drive F. <<
All I can do is use Task Manager to terminate. Do you know what the file is?
Properties for the shortcut are correct: G:\SOFTRAK\JobCost\JobCost.exe
When I run Allwkst for JC, here is what I get on dEtails For:Adagio Job Cost: MASTER INSTALL INFO: Workstation Version: 20090633 Program Version: 9.2A (160126) Date Installed: 03/09/2016 10:46:17 Group: Adagio Sub-group: JobCost
WORKSTATION INSTALL INFO: Workstation Version: 20090633 Date Installed: 01/26/2017 11:10:38 Group: Adagio Sub-group: JobCost
FYI AP does not work either. Here is the Allwkst Details for Adagio Payables: MASTER INSTALL INFO: Workstation Version: 20140733 Program Version: 9.2A (150609) Date Installed: 03/09/2016 10:12:31 Group: Adagio Sub-group: Payables
WORKSTATION INSTALL INFO: Workstation Version: 20140733 Date Installed: 01/26/2017 11:11:19 Group: Adagio Sub-group: Payables
Here is new a GetWorkstationInfo for both AP and Jobcost: Adagio Workstation Information [as of 1/26/2017 11:21:27 AM] Run from [G:\SOFTRAK]
=========================================================================== Adagio JobCost === Company: [] Wkst Version: Registry [20090633]; {must be >=} Main [] Report Tables Status: Result is OK: [True]; {Is Eval. version: [False]} Report Tables drive: CU Registry [G:\]; CU UNC [\\winserver\accounting\]; LM Registry [G:\]; LM UNC [\\winserver\accounting\] ----- Registry Trace: ----- ***** Adagio JobCost STATUS: WORKSTATION UPDATE REQUIRED. ***** =========================================================================== Adagio Payables 9.2A (150609) === Company: [A&B Flooring Systems, Inc.] Wkst Version: Registry [20140733]; {must be >=} Main [20140733] Report Tables Status: Result is OK: [True]; {Is Eval. version: [False]} Report Tables drive: CU Registry [G:\]; CU UNC [\\winserver\accounting\]; LM Registry [G:\]; LM UNC [\\winserver\accounting\] Resources: Flags [CIXM9PwR] Web storage Exe: [] PDF Must update: [False]; Reg: [20110510] >= File: [20110510] {LM: [20110510] CU: [--not checked--]} Crystal Scheme OK: [True]; Reg. [20140630] >= Min. [20140630]; dotNET Scheme OK: [True]; Reg. [394802] >= Min. [378389]; ODBC Component Path: [\\winserver\accounting\SOFTRAK\ODBCV2\AdagioODBCv2.dll] ODBC Component Scheme OK: [True]; File. [2.1.8.189] >= Min. [2.1.7.147]; --- NOTE: ODBC Component is in a different Softrak Folder! System Files: Components: [INST PRGR CR_20140630 DN_378389 OD_2.1.7.147] No QRW Files. ----- Registry Trace: ----- HK_LM: [Software\Softrak Systems] {Default:}; exists: [True];+Opened; . .Key: [AdagioPDFVersion] exists: [True] Value: [20110510] HK_LM: [Software\Softrak Systems] {Default:}; exists: [True];+Opened; . .Key: [AdagioCR_InstallerVersion] exists: [True] Value: [20140630] HK_LM: [SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full] {Default:0}; exists: [True];+Opened; . .Key: [Release] exists: [True] Integer Value: [394802] HK_LM: [Software\ODBC\ODBC.INI\Adagio Data Source] {Default:}; exists: [True];+Opened; . .Key: [Driver] exists: [True] Value: [\\winserver\accounting\SOFTRAK\ODBCV2\AdagioODBCv2.dll] ***** Adagio Payables STATUS: OK - NO Workstation Update Needed. *****
#52435 - 01/26/17 10:00 AM
Try restarting the computer. If it doesn't work, check if there are any errors on the right bottom corner related to synchronize files conflicts. In some weird cases, I found that the file synchronization has been enabled and Adagio is using a copy of certain files on the local machine causing issues.
This happens when file synchronization is enabled and there has been a disconnection from the network at some point.
#52441 - 01/26/17 02:02 PM
In my first post, I stated that all other workstations were running Adagio w/o issue.
They did reboot the pc -- they did that a couple times before they even called me. I'll have their IT person check out about the synchronize files.
0 registered (),
209
Guests and
Spider online. |
14666 Topics
