#49390 - 03/24/16 11:37 AM fiscal year end
Deb Offline
Good Morning,
I have done year end before so should know the answer to this ...but apparently I am second guessing myself. I realized that the new fiscal year can be opened in the GL anytime now..our year end is March 31st. Can I continue to enter batches in AP for the current year and the new year before I actually run the year end function in AP? I know if I have both years open in the GL batches will post to the correct fiscal year, just not sure about the timing of the year end function in AP. Thanks
#49391 - 03/24/16 11:44 AM Re: fiscal year end [Re: Deb]
Hi Deb
The timing of year-end in AP is always tricky because there's never a clean cutoff. Running year-end has no effect on entering transactions dated in the prior year. Since it doesn't really matter anyway, I would suggest you time the year-end to be after your last check run, which is something you have control over.
#49392 - 03/24/16 12:23 PM Re: fiscal year end [Re: Steve Schwartz]
Deb Offline
Thanks Steve,
That's what I thought, However, I think I can wait until all March invoices are in and still enter April invoice batches and retrieve to the GL. Then run the year end function with a March 31st date? Then I would have an open payables summary that would include the March invoices. Make sense?
#49394 - 03/24/16 01:07 PM Re: fiscal year end [Re: Deb]
The only thing that Year End does in Payables is reset the batch numbers and YTD statistics.
#49395 - 03/24/16 01:56 PM Re: fiscal year end [Re: Retired_Guy]
Hi Deb
Year-end processing is totally unrelated to the Open Payables report. Andrew's reply says it all.
I would not wait until all March invoices are in. I would run Year-end once the last check run is done for March.
#49397 - 03/24/16 02:12 PM Re: fiscal year end [Re: Retired_Guy]
The AP Year-End process also has a negative effect - it purges the posting journals. It's important to print the PJ reports to PDF for future review.
#49400 - 03/24/16 04:07 PM Re: fiscal year end [Re: Bruce Gardner]
Hi Bruce,
Well, of course I would have expected that ePrint would have taken care of that for you! smile
1 registered (accountability), 126 Guests and 1 Spider online.
14668 Topics
