#47694 - 10/28/15 11:50 AM Payables 9.2A Batch Numbering
Dwaine_Went Offline
Adagio Fan
Loc: Barbados
I am experiencing an issue with Adagio 9.2A. We did a Year End and the batch numbers for Invoices and Manual Checks do not restart from 1.
Invoice Batches start from #2 and Manual Checks start from #3.
I did a Data Integrity on a back done before the year end and tried the process again Test Data and I got the same result.
Any assistance would be appreciated.
#47699 - 10/28/15 02:11 PM Re: Payables 9.2A Batch Numbering [Re: Dwaine_Went]
Dwaine:
Which version did you upgrade from?
There was an issue, many years ago, with orphan batch files being skipped but I thought that Softrak had added a process to the data integrity check that cleaned them up.
Someone who is very familiar with Adagio databases needs to take a look for orphan batch files and remove them. Your Adagio dealer should be bale to help you out.
#47709 - 10/29/15 06:49 AM Re: Payables 9.2A Batch Numbering [Re: Douglas Dickie]
Dwaine_Went Offline
Adagio Fan
Loc: Barbados
Thanks for your reply. I think since data conversions to versions 8 and 9 we don't see the batchs in the Data anymore.
#47710 - 10/29/15 08:06 AM Re: Payables 9.2A Batch Numbering [Re: Dwaine_Went]
You can still see them in AP 9.2A. They'll be gone in AP 9.2B.
If Payables goes to create a batch, and the batch is already there, then the batch number is skipped.
#47711 - 10/29/15 08:57 AM Re: Payables 9.2A Batch Numbering [Re: Dwaine_Went]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
Hi Dwaine,
You're right that the 9.x upgrade to some modules changed the batch structure in a way that meant you did not see individual files for the various batch types any longer but this did not happen for AP. I believe the AP move to 9.x was mainly to do with its Cloud readiness and the batch structure changes are coming later.
In the pre-year end backup, look for API0001?.xxx, APC0001?.xxx and APC0002?.xxx (where the I = Invoice batches, the C = Manual Check batches, the xxx = your specific data selector and the ? could be D, H or I. If you see them, give me a call and I'll give you the procedure to correct depending on how much work you've done since and how important the sequencing is to you.
Best, Pete
Peter Banfield
BAMPH Consulting Services
Barbados
#47754 - 11/02/15 06:49 AM Re: Payables 9.2A Batch Numbering [Re: BAMPH]
Dwaine_Went Offline
Adagio Fan
Loc: Barbados
I thought the file conversion was across the board of modules, so Douglas you were initially correct about the orphan batch files; thank you.
From within the company Data Set I was able to remove the orphan batch files since Pete was able to help me identify them (I noticed the date modified on the files were old as well).
So I went through the following process:
Restored from backup,
Removed the orphan files
Did a Data Integrity (which was error free)
Created New Batches
End Result: Number sequence was correct.
Issue Resolved. . .
Thank you very much everyone!
0 registered (), 212 Guests and 3 Spiders online.
14668 Topics
