Previous Thread
Next Thread
Print Thread
Page 1 of 2 1 2
I have reports designed for AR 9.2A (150625) that run fine on my install.
When transferred to the customer, pressing "preview" after selecting the custom report results in an "Unspecified Error".
I just noticed the AR about screen says it is AR 9.2A (150701) ??
Any ideas?
Tony Martin
Code 6 Programming
519.359.0918
S
S Offline
Hi Tony:
I likewise have had this problem, and reported in on the Forum a number of weeks ago.
Problem is, I sent the data and reports to Softrak and they are able to run the reports without the error message, but I still cannot run them from within Adagio 9.2.
The reports that bomb-out in Adagio work fine when I run them from Crystal.
This issue is not resolved for me yet.
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
Hi Samuel:
Did you see my note about the version...what version does your AR report?
Tony Martin
Code 6 Programming
519.359.0918
S
S Offline
I am running the reports accessing tables from OE & AR.
The AR is 9.2A(150410).
The OE is 9.2A(150729)
(I am trying to use the most-current versions.)
Samuel Kopstick
Toronto, ON
A common problem with Crystal Reports "works for me and not the client" is the printer driver. Try printing to AdagioPDF.
I've tried printing to AdagioPDF ...same result.
Tony Martin
Code 6 Programming
519.359.0918
Hi Tony,
Other possible differences may be the dictionary used for creating the report (ie you have a dictionary in \softrak\dict that your client does not have), or that you have MS Visual C++ Runtime versions on your workstation that your client does not have. Perhaps there are other system files or other differences apart from these.
Are you creating CustomReports or ModifiedReports to run from Adagio? Or is PrintTool being used to print the custom report? That might make a difference, particularly with the ODBC connection but perhaps also the dictionaries.
I presume that your client is able to print the Standard Reports in Adagio 9.2A successfully and it is just the custom-written reports with a problem.
I could not locate a particular reason for the 'Unspecified Error' message.
S
S Offline
I changed the report printer in the Crystal Report to AdagioPDF & re-saved the file.
(And just to be sure, I uninstalled on my laptop the ODBC and re-installed.)
The report is saved to C:\SOFTRAK\Receivables\CustomReports
In Adagio AR, I ran the report twice from two separate companies (different clients' data), but the end result is that we still receive: "Unspecified error"
When I run the same report from Crystal, the report runs properly.
Samuel Kopstick
Toronto, ON
Tried printing with PrintTool....prints fine when using "saved data", but crashes when I try to refresh.
I'm thinking it's one of two things:
Parameters: Report has parameters. They aren't fancy, don't look up info and aren't cascading.
ODBC Driver: I've noticed there are some things I can't do in Crystal while using the Adagio ODBC (like using formulae in linking), perhaps one of the Crystal functions I've used (inadvertently) is causing the ODBC read to fail.
As an immediate solution, this client is buying Crystal for themselves and I will recreate the report on site.
I'll keep you posted...
Tony Martin
Code 6 Programming
519.359.0918
I doubt this will solve the problem, but you shouldn't be saving the data with the report.
If you want, you can upload the data and the RPT and we can try and recreate the problem here.
Page 1 of 2 1 2
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
