Posts: 28 |
I have multiple Ship To addresses that I will use only once. Is there anyway I can manually enter the ship to information in POs without having to create a code every time?
thanks, Vickie.
Posts: 11,746 |
Hi Vickie,
The original architecture of the Purchase Orders database was to store ship-to addresses as codes that can be referred to from the PO, rather than storing the address directly on the PO. The editable information - Comment and Contact - is stored on the PO, but not the rest.
So until the data structure is changed to save the ship-to (and bill-to) address fields on the PO, then it is a requirement to create a new code every time a new ship-to address is desired.
Just curious, but how often and how many one-time ship-to addresses do you typically have?
Regards, Softrak Tech Support
Posts: 28 |
Currently 4 to 5 every day, I created a Miscellaneous code and the purchaser edits the code as he does the various POs. It works fine as long as he prints the PO before moving on to the next one since the ship to address will be incorrect moving forward, as the code gets changed for the next PO.
However, we will be increasing exponentially this side of our business and we have to issue these POs to our sister facility (on Adagio, but different dataset). I was hoping to export the POs from one dataset and load them as orders in the other. I came across this issue and also that the PO module doesn't have an export PO function, so I'm using Crystal for that function.
thanks,
Terry
Terry
Posts: 276 |
Hi Vickie,
POTracker stores the Ship To and Bill To information with the purchase order. A code does not have to be created for each Ship To, to use it on a PO.
The report designer that is included with all our applications can print to a file in various formats that could be imported to another application.
Terry IMS Island Microsystems Ltd 250 287-9874 terry@islandmicro.com www.islandmicro.comIMS Applications: CounterSales . JobTracker . POTracker . LabelPrint . LotTracker . SerialTracker . IMScheduler . ReportGen JobTracker can now use ServiceTracker to track jobs performed on Equipment and Machines. Call for more information on our applications or to arrange a Demo.
Posts: 10,504 |
Hi Vickie,
Isn't the drop ship information for the PO actually a customer of yours? Wouldn't you want their contact information?
In any event, you can add Ship To codes and records "on the fly" as you create the PO. Why not develop a method of generating unique codes every day. For example, you could use "Ymmddx" where "Y" is the year, "mm" is the month,"dd" is the day and "x" is 0-9,"A-Z" for 36 new customers / day. Or use your UserId and 3 digit codes, allowing 1000 addresses per user until you need to start again.
Posts: 28 |
I certainly can create new Ship to as we go, that's a good idea. It would be even better if I could import the ship to from the work order (OE). Is that possible?
thank you
Posts: 10,504 |
Hi Vickie,
Is the suggestion that we load the PO Bill-to/Ship-to address from (either) the Bill-to or Ship-to address on a Sales Order in OrderEntry, when that Sales Order is used to auto-generate a PO?
Posts: 28 |
Yes Exactly, that would be a fantastic option to be able to import the Ship To from OE when importing the order in PO. This is a great one for the Wish list.
Posts: 10,504 |
Hi Vickie,
How would PO "know" whether to pick up the Bill-to or Ship-to address from the Sales Order? How would it decide whether to use the Bill-to / Ship-to from the SalesOrder, or to specify your own location?
I think there would have to be several fields added to a Sales Order to specify how the matching PO was to be generated.
Posts: 11,746 |
If Auto Generate is not used, when you create a new Purchase Order and use ‘Import OE Lines’, PurchaseOrders can pick up the Customer’s Ship to address.
Make sure that the Ship To code field is blank on the Bill to/Ship to tab. Then, choose the ShipTo button. You will see a confirmation message, ‘Do you want to create a ship to address, and use the OE address as the default?’.
If you say yes, a new Ship/Bill to Address will be created with the Customer number as the Ship To Code. The Ship-to Address comes from the OrderEntry Order and the Bill-to Address comes from the PurchaseOrders Company Profile.
If an address is already on file for the customer, you will be warned and you can update the existing address.
0 members (),
71
guests, and
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
