Humble Adagio Monk
Humble Adagio Monk
Posts: 183 |
I have a client who uses FX for consolidations from about 12 companies. Each company has dozens of departments which is constantly growing because each department represents an employee. Using the AutoRetrieval function makes them add a new department for each new employee to the SelectedDepartments= line in the AFWININI file. Is there a way to use a wild card so that all departments are brought in without specifying each individual department? The manual Retrieval works fine for them but is cumbersome to select each subcompany and folders for the 12 companies. We are trading one tedious issue with another if we use AutoRetieval.
Here is a sample of the Retrieval sections currently used: [Retrieve1] Database=P:\Quantum\FX Imports\SUBDATA\glglob.sub UserID=sys Password=sys SelectedDepartments=252236,303169 Department=101* ReplaceDepartment=0 AppendData=0 UseExistingBudget=0 UseExistingGroups=0 UpperCase=0 LoginPrompt=0 RetrieveAllYears=1 [Retrieve2] Database=P:\Quantum\FX Imports\MEXDATA\glglob.mex UserID=sys Password=sys SelectedDepartments=306100,306101 Department=201* ReplaceDepartment=0 AppendData=1 UseExistingBudget=0 UseExistingGroups=0 UpperCase=0 LoginPrompt=0 RetrieveAllYears=1
etc...
Thank you for any response. RES
Robert E. Schwoeffermann Ledgerwood Associates, Inc. (503) 522-5601 LedgerwoodAssociates.com
Posts: 4,506 |
Bob:
One of my clients using FX also has a database where new departments are added all of the time. We use the auto retrieve:
[Retrieve11] Database="G:\DATA\HYSCAL\CONST\GLGLOB.CAL" UserID="FX" Password="FX" Department="CALC" AppendData=1 RetrieveAllYears=1 ReplaceDepartment=1
For your purposes I wonder if this would work (changing our setup from creating a fixed department in FX to one that should create a variable department):
[Retrieve11] Database="G:\DATA\HYSCAL\CONST\GLGLOB.CAL" UserID="FX" Password="FX" Department=CALC* AppendData=1 RetrieveAllYears=1 ReplaceDepartment=1
We are not using 'SelectedDepartment' at all, which (I assume) means that we retrieve them all.
Humble Adagio Monk
Humble Adagio Monk
Posts: 183 |
Doug
I will test it without the SelectedDepartment and let you know my results.
RES
Posts: 10,504 |
Isn't it self-evident that "SeletedDepartment" means you want only the departments specified to be selected and that the retrieve would normally retrieve all the departments?
Posts: 4,506 |
Andrew:
I think that what is not self evident is that fact that you don't need to use all of the auto retrieve options (as evident from Bob's post where is using every possible option when only a few are really required).
Posts: 839 |
If the OPTION is NOT there then it is the same as OPTION=0
Humble Adagio Monk
Humble Adagio Monk
Posts: 183 |
Gang
I adjusted my autoretrievals in the AFWININI file by eliminated the SelectedDepartment option. I got the result as Andrew indicated of all accounts and departments from the respective GL datasets with the proper assigned prefix. I think I asked tech support about a year ago about using a wild card with the SelectedDepartment option but they said no it would not do what I wanted. They did not tell me that eliminating it or giving the option =0 would do what I wanted.
It was not self evident that I could remove the command option. I thought that since it was there I had to use it.
I think this will make my client very happy.
RES
Posts: 10,504 |
That's what we're looking for - happy clients!
Humble Adagio Monk
Humble Adagio Monk
Posts: 183 |
Gang
Final results were tested today and the auto retrieve worked perfectly for the client. Thank all of you for your help.
My next question is there a document explaining the Retrieve options and how or when to use them?
RES
Humble Adagio Monk
Humble Adagio Monk
Posts: 183 |
Gang
RES
0 members (),
1,119
guests, and
robots. |
Forums5
Topics14,680
Posts71,644
Members1,874
S |
M |
T |
W |
T |
F |
S |
