Posts: 337 |
When I went to www.softrak.com on the old website, there was a search box available at the top. I would use it to search for a question I had before posting to the technical support forum. It was better than using the search box in the forum itself. It seems to have disappeared and I miss it. If it still exists, could someone point me in the right direction? Also, where are the manuals for the modules now located? Having trouble finding them. And since I'm looking for things, I checked the YouTube channel for a training video and couldn't find it - Advanced GridView. Any ideas? Lastly, is there a sample file for importing a quote into SaleCQ? Thanks for the help.
Mike Smith Viktorian Sheet Metal Mfg Inc
Posts: 694 |
Further to the new website comments ... Where are the upgrade downloads?
Posts: 11,746 |
Hi, Ralph,
Links are provided within the Partner Portal under Software, as well as in the Client Portal under Downloads, Software. Links are also provided in the spreadsheets you receive.
Regards, Softrak Tech Support
Posts: 4,506 |
Mike: Use Google for all searches. Softrak's new website is designed to make use of Google search engine. I searched 'Adagio manuals' and found this http://softrak.com/products/documentation.phpThe video's are readily available in the client portal. Sample import files are available in every sample database, there should be one in SalesCQ for quotes. I also seem to recall someone mentioning that they were also available on Softrak's website but I wasn't able to find anything. Ralph: Dealer or end user installs? Both are easily obtainable in their respective portals.
Posts: 11,746 |
Hi, Mike,
Within the Client Portal (just sign in), you'll find the manuals and such under Documentation, Product Documentation.
You'll also find both the Webinars and Show Me How videos (along with the Tech Tips) here under Online Training.
Regarding a simple quote import file, yes, there is such a file.
Using sample data (Softrak\ACWIN\Samdata extension SAM), select File | Import | Quotes. You'll see on the resulting File Information tab that the sample import file is QTQUTIM.CSV. There are 6 sample templates provided. Choose the template you're interested in and add that number to the file name (eg. QTQUTIM2.CSV) or use the Browse button to drill down to the folder and files.
Posts: 337 |
Hi Doug/Support
Thanks for the direction. But if you notice, there is no documentation link on either the public web page or the client web page. I did see "Adagio Modules" under products but the links for the different modules just sent me to advertising. I would suggest that there be a link to the documentation page, and/or a direct link to documentation under Learning Centre.
As for Google searches, the old website used a Google base search (I think) but it searched the Softrak site first and then the whole web. No need to type in Adagio, and the searches generated more relevant results. And it is very important to put 'Adagio" first in any search inquiry. Using "adagio sample quote import " returned what I wanted as the first result, whereas "sample quote import adagio " returned something completely different. (I found out that my memory is terrible because I had already asked this question once before.)
I didn't see Online under Education. I guess I was looking for Webinars or How To.
Posts: 476 |
About searching the softrak website/forum, you can tell google to only return results within them by starting your search with (without quotes) "site:www.softrak.com ". That is my goto way of finding information within the site and general discussion forums.
Posts: 11,746 |
Hi, Mike,
Look on the right side of the page under Support. Documentation is in 'red'. Please select the Product Documentation link. Products are listed alphabetically.
The website has been redesigned with an initial look to persons visiting the site as prospects.
As with the Forum previously, existing clients should Sign In (or Register first if they haven't already) and then access the Client Portal button presented at the top of the page. The Client Portal contains links to the Forum, software downloads, product documentation, webinars, Show Me How videos, etc. used by existing clients.
Posts: 11,746 |
Hi Mike,
Just an FYI about the training videos, that the shorter videos are on the YouTube channel, and the hour-long recorded webinars such as 'GridView - Advanced' are stored in a separate place as they are generally not publicly available but rather only for Adagio clients on a current upgrade support plan. All videos can be accessed from the Client Portal, as has been previously indicated.
Posts: 337 |
Sorry, I'm an idiot. I thought signing in was enough. I forgot you had to then click on client portal. Any reason we can't be taken right to the client page upon sign-in?
0 members (),
70
guests, and
2
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
