Previous Thread
Next Thread
Print Thread
J
J Offline
Good day to you all,
One of our workstations can print from the Adagio modules w/o a problem apart from when trying to run financial reports which usually ends in a windows spooler error.
Weirdness about us!
Any hints as to what might causing this would be very much appreciated.
As always, thank you and,
Cheers, JK
J
J Offline
The problem has gotten worse - Adagio Ledger Financial Reporter is causing Payables (even in different data sets) to go "Not Responding".
When we close the financial reporter and boot the server things are all good.
We have duplicated this behavior on three computers..
Any ideas?
Cheers, JK
John:
If anyone monitoring this forum had any idea what might be causing this problem they would have responded by now. No response usually means that no one has seen the issue you describe.
Your Adagio dealer should be able to help you track this down.
J
J Offline
Hi Doug,
Thank you for your reply.
I took some measures that resolved our problem yesterday which I will share with everyone.
I have had exposure to ISAM in the past and noted the same kind of behavior when large indexes were open across several workstations on a less than perfect network.
This got me to thinking about our recent addition of Voip to our network and how our computers were now connected to the phone which was connected to the new fancy PoE router.
This was the only thing that has changed and of course, once thinking about it a bit it became obvious that to support Voip a small MTU block size is required which of course makes the phones work well but not so great with ISAM indexes.
So, i reconfigured our network and split the traffic up - voip on one and data on the other.
Problem solved!
Moral of the story: do not use Adagio on a network which is optimized for Voip.
Thank you for your suggestion to reach out to our Adagio dealer.
I did reach out and heard back from him (Tony Martin - a great guy) with confirmation about how a small MTU block size can affect Adagio.
Again, thank you for posting up, keep well and,
Cheers, JK
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
