#39568 - 12/16/13 01:44 PM Restore backup
Karre Offline
Casual
Loc: Thunder Bay, Ontario
Hello! I made a mistake when doing my bank rec. How do I get back the backup that I did right before I imported my bank statement?
#39570 - 12/16/13 02:21 PM Re: Restore backup [Re: Karre]
Hi Karre,
Are you just wanting to undo the import of a bank statement, or do you want to undo the posting of the the reconciliation?
If all you want to do is undo the import (that hasn't yet been posted), so that the transactions do not appear on the left-hand side of the reconciliation window, you can multi-select all the imported transations on the left side and press the Delete key on the keyboard. This will mark all the imported reconciliation transactions as Deleted, so when you close and re-open the Reconciliation for that bank, the imported transactions will be gone. Then you can either re-import the file or continue with other tasks.
If you really do need to restore data from a backup copy, it all depends on how and when you do your backups. You may be able to remove and restore just the BankRec data, or you may need to remove and restore related data such as for Payables, Receivables and Ledger. This advice is best asked of your Adagio Consultant who can assist and determine where backups are kept and how much you need to restore, and do it the correct way.
1 registered (C White), 92 Guests and 3 Spiders online.
14593 Topics
February
