#37608 - 06/27/13 09:41 AM
Adagio Ledger - Print detail listing error...
Good day to you all!
I hope this posting finds everyone enjoying the opening days of summer <grin>!
We are trying to print a detailed listing report in Ledger and are receiving (but only under certain profiles) the following error message:
"Unable to open data file master accounts net change @LD90DBUK, (123)"
Going to a different windows profile seems to solve the problem.
Perhaps this is an ACL problem?
Any idea on where to look?
Thank you and,
Cheers, JK
#37612 - 06/27/13 11:49 AM
Re: Adagio Ledger - Print detail listing error...
[Re: Softrak Support]
Hi support,
Thank you - this is very helpful.
I will reset the ACL in the noted folder and revert once completed.
Again, thank you and,
Cheers, JK
#37613 - 06/27/13 12:11 PM
[Re: JohnK]
Well, that was not what I expected...
There is no @L90DBUK file in the ..\softrak\dict folder...
There are @L90DI.ssi & @L90DR.ssi but that is it!
#37616 - 06/27/13 01:50 PM
Thank you!
I have reset the ACL to the entire Softrak folder - still the same problem <argh>...
I ran the test on the Ledger\Samdata and the report ran w/o a problem using the problematic profile.
Since the ACL is correct, the reports works on the Samdata I then believe that this might be a hung file open operation or some kind of lock like you refer to.
I will reboot the server tonight and post back up once I know the results..
Again / always - thank you for your support!
Cheers, JK
#37622 - 06/28/13 07:00 AM
[Re: JohnK]
Good morning y'all!
I hope this posting finds you all well and planning a great long weekend!
I rebooted the server (ie: dealt with a possible file open issue) with no change.
I added the domain admins group to the problematic profile and it runs all the reports w/o a problem.
If this is an ACL issue then the problem accessing the dictionary would occur across all datasets but the report prints on most databases - the error only happens on one dataset so far but for several users...
So the question becomes - what could cause varied behavior when accessing this dictionary
Very strange indeed...
Any ideas anyone?
Thank you and,
Cheers, JK
#37624 - 06/28/13 09:02 AM
[Re: JohnK]
Loc: Chatham, Ontario, Canada
Hi John:
The dictionary @LD90DBUK points to the version 9.0C files GLNUMB'R and the indexes GLNUMB'x (where x = 1 to 5).
Those are the files that you need to look at regarding rights.
Tony Martin Code 6 Programming 519.359.0918
#37629 - 06/28/13 10:54 AM
[Re: Tony Martin]
Hi Tony,
Many thanks...
Somehow the ACLs on those files did not include the user group for that database.
Not too sure how this happened but I am certain there is a good reason - aka tightening security means files created before a certain date may only carry the higher level acl (sounds like a mea culpa!)..
I have reset the ACLs and the problem has disappeared..
Thank you Tony!!!!
