Previous Thread
Next Thread
Print Thread
L
Adagio Graduate
Adagio Graduate
L Offline
Last night we upgraded several modules, in particular we upgraded OE from 8.1C to 8.1E. In several Workstations the specific printer for Picking Slips is set to Print Boss...however when they select PRINT, it wants to print to the default printer. Should I have updated Print Boss as well (is there an updated version?)
Thanks in advance
B
B Online: Content
Liz:
In OE, go to File | Workstation Options and select the tab labelled "Specifications". If the Pick Slip isn't already pointing to PrintBoss, make the change. Note that "Workstation" is meant literally; you will need to make the change on each computer running OE.
A new version of OE will not need a newer version of PrintBoss. The next time would likely be when you change to a new operating system (ie. from XP to Windows 7 or Windows 8).
L
Adagio Graduate
Adagio Graduate
L Offline
Bruce - I have done this on the different workstations & it won't "stay"...interesting enough, this only seems to be affecting the "picking slip" option - if I change the Invoice option, it sticks?????
I am still trying to figure this out (and going grey in the process:))
L
Adagio Graduate
Adagio Graduate
L Offline
I found something interesting....if I print from the "Orders" window (right click order, select print) it will not use my preferences, but if I select from the Menu Bar - "Order Entry -Print Picking slip" it will use my preferences?????
L
Adagio Graduate
Adagio Graduate
L Offline
I lied - this did not work -
M
M Offline
Contact your dealer to get the hot fix..
AdagioŽ OrderEntry 8.1E (Hot Fix)
In OrderEntry 8.1E (2011.12.15) the specific printer setting for Picking Slips was not respected.
L
Adagio Graduate
Adagio Graduate
L Offline
THANK YOU!!!!
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
3 members (Dan_Desautels, Bruce Gardner, Douglas Dickie), 115 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,626
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
