Posts: 164 |
Good day everyone,
Most reports have an output process which defaults to “Printer” which means the user has to select something else everytime.
Is there a place to set this so that the default destination is something other than "Printer"...
Thank you and,
Cheers, JK
Posts: 10,504 |
Use Adagio ePrint and turn on "Paperless" under User Preferences and the output will be automatically named and filed in a Folder as a PDF.
Posts: 164 |
Thank you for the recommendation however my question stands.
We are not looking for a work around - the user wants to change the default from printer to file.
Is their a way?
Thank you and,
Cheers, JK
Posts: 11,763 |
No, the default is always printer.
Regards, Softrak Tech Support
Posts: 839 |
And, I suspect, which would then default to your "Windows Default Printer" which could be something green.
Posts: 164 |
Roger wilco...
A path forward ...
Thank you!
Posts: 839 |
I believe the "user" will soon get tired of entering a "file name" for the green output.
Posts: 164 |
Good point - I am pretty sure the PDF engine we use provides a default file name so, hopefully the users will just be able to hit "Ok, Ok, Ok" kind of thing.
Does the built in Adagio PDF writer allow for a preview right after the file is created w/o keyboard input?
Thank you!
Posts: 839 |
As Andrew said: Use Adagio ePrint and turn on "Paperless" under User Preferences and the output will be automatically named and filed in a Folder as a PDF. Adagio ePrint is a "solution" NOT a "work around".
Posts: 11,763 |
When using Adagio ePrint to generate PDF outputs of reports, there are options to allow immediately opening the PDF to view without any mouse-clicks, or opening the folder in Windows Explorer where the PDF was saved. These options can be set on a report-by-report and user-by-user basis.
0 members (),
78
guests, and
robots. |
Forums5
Topics14,682
Posts71,653
Members1,875
S |
M |
T |
W |
T |
F |
S |
