#33569 - 10/12/12 12:36 PM Open Cash batch in year end close
PLane Offline
Casual
Loc: BC
I am trying to close year end in AR, but it tells me a cash batch needs to post, but there are none to post. I ran integrity and everything is fine. Is there something else I can try.
Pat
#33571 - 10/12/12 12:43 PM Re: Open Cash batch in year end close [Re: PLane]
Hi Pat,
What version of Adagio Receivables are you using? You can check the Help / About menu for the version and release date.
If integrity is clean, what does the Batch Status report or inquiry indicate for cash batches? Perhaps something is listed there that does not appear on the Edit Cash Batch list. Though this would appear as a data integrity error.
And just to confirm, is Year End expecting a cash batch to be posted, or a cash posting journal to be cleared? The posting journal scenario tends to be more common because the file was not cleared when it should have been.
You probably will need to get your Adagio consultant involved.
#33573 - 10/12/12 01:35 PM Re: Open Cash batch in year end close [Re: Softrak Support]
PLane Offline
Casual
Loc: BC
We are running version 9.0B for AR
I found a batch listed under batch status that is $0 and shows open. It has a date of 27A/08/2011 under created by and a date of 27/08/11 as date created. Our year end is Sept 30, so this batch is from the previous year end.
Year end is expecting a cash batch to be posted.
Pat
#33637 - 10/18/12 10:08 AM Re: Open Cash batch in year end close [Re: PLane]
PLane Offline
Casual
Loc: BC
Any ideas on my AR issue?
Pat
#33638 - 10/18/12 11:00 AM Re: Open Cash batch in year end close [Re: PLane]
Can you delete that batch?
#33640 - 10/18/12 01:05 PM Re: Open Cash batch in year end close [Re: Retired_Guy]
PLane Offline
Casual
Loc: BC
I can only see the batch in the reports, but it is not available to delete.
Pat
#33643 - 10/18/12 01:12 PM Re: Open Cash batch in year end close [Re: PLane]
If you cannot print and purge the batch status report to resolve this, then you will need to get your Adagio Consultant involved, as the data is out of synch and corrupted, regardless of the clean status that DIC is giving you.
1 registered (1 invisible), 235 Guests and 1 Spider online.
14636 Topics
