#31159 - 03/03/12 04:25 AM Report table error
Mach Offline
Loc: Nova Scotia, Canada
I just moved a client from an old Server (2003 & workstations with mapped drive to the server). Old server had Adagio installed to a mapped (K:\ drive).
To a new server - Server 2008 with all users logging in to the server using terminal services (RDP). Everything was installed on the new server to the C:\Softrak folder
I moved the Adagio folder from the old server to the new, and installed all the new modules on top.
During installation I got these error messages:
When Adagio BankRec was installed, its Report Tables drive was specified as (C:) which is a non-network drive.
WARNING! Workstations that use a non-network Report Tables drive may not access vital shared information!
and:
The Report Tables drive (C:) does not have the Adagio BankRec Tables installed invalid (\qrasp\qrtables.ini). Please check that you have selected the proper directory and if necessary, re-install Adagio BankRec.
When I go to C:\Softrak\qrasp\qrtables.ini, there's no place that I see where I can change it so that it points to the C:\ drive as the reports table drive.
Finally - just to point it out - all the modules work fine. I can open them, login, process transations, etc. The only one that won't is multicurrency - when I try to open Multicurrency, I get this error message:
The Report Tables drive [C:\] does not point to valid Reports Tables for this program.
To correct, please check with your Dealer or qualified Adagio expert to do one of the following:
1. Run the workstation setup program if you haven't already (WkSetup\WkSetup.exe);
2. Check and adjust your workstation drive mappings;
3. Run the Adagio utility \Softrak\System\SetReportsTableDrive.exe to properly set the Reports Tables drive;
4. If necessary, re-install the Adagio program.
I've already ran Wksetup, I ran the Adagio utility to set report tables, it doesn't look like it does anything.
I feel like all the above issues are 1 issue.
Where can I go to set the report tables to C:\ and have the modules not complain about that?
I've rebooted the server, reinstalled modules
#31161 - 03/05/12 03:27 AM Re: Report table error [Re: Mach]
Mach Offline
I moved over the MC*.LD4 files, and I checked the currency path in the ADSPROF.XXX file – it’s pointing to the new location (C:\Softrak\system)
I also did a reinstall, restarted their server and it’s still not working.
Anything else that I should check?
#31163 - 03/05/12 06:38 AM Re: Report table error [Re: Mach]
Bob Wisener Offline
Adagio Conductor
I'd recommend that you run \Softrak\System\chksys.exe for more information on the problem.
Bob Wisener
Dakota Software
#31164 - 03/05/12 06:51 AM Re: Report table error [Re: Bob Wisener]
Mach Offline
When I run chksys I get 28 errors:
======= Checking Special System Configurations ======
WARNING: Potential Multi-user folder problem! Click View Session Details, or see Log for details.
========== Checking 32-bit System Status ==========
--- OK ---
======= Checking Report Tables Configuration =======
*** NOTE: Report Tables drive is: [C:];
Override status for user [Administrator] is [Y].
=============== Checking Products ==============
Adagio BankRec Status:
*** Configuration error - missing entry in C:\qrasp\qrtables.ini.
C:\qrasp\QRTBRW80.qrw
Date: [06/09/2011] OK.
C:\qrasp\QRTBRZ80.qrw
Date: [03/28/2007] OK.
C:\qrasp\QRTMCW80.qrw
Date: [08/12/2003] *** Error; Needs: [04/03/2008]
C:\qrasp\QRTBRB81.qrw
Date: [06/21/2007] OK.
C:\qrasp\QRTBRZ81.qrw
Date: [03/30/2011] OK.
Adagio DataCare Status:
C:\qrasp\QRTDCW80.qrw
Date: [11/21/2010] OK.
Adagio Inventory Status:
C:\qrasp\QRTICW81.qrw
Date: [06/10/2011] OK.
C:\qrasp\QRTICZ80.qrw
Date: [03/19/2009] OK.
C:\qrasp\QRTICW65.qrw
C:\qrasp\QRTICZ81.qrw
Date: [05/21/2010] OK.
Adagio Ledger Status:
*** ERROR: Missing Report Table [C:\qrasp\QRTALW65.qrw]
*** ERROR: Missing Report Table [C:\qrasp\QRTALZ80.qrw]
Date: [08/12/2003] *** Error; Needs: [10/15/2006]
C:\qrasp\QRTALW90.qrw
Date: [05/31/2011] OK.
C:\qrasp\QRTALZ90.qrw
C:\qrasp\QRTSMZ90.qrw
Date: [10/24/2008] OK.
Adagio MultiCurrency Status:
Adagio OrderEntry Status:
C:\qrasp\QRTOEW65.qrw
Date: [09/09/2010] OK.
C:\qrasp\QRTOES65.qrw
Date: [09/13/2001] *** Error; Needs: [09/14/2001]
C:\qrasp\QRTOEZ80.qrw
Date: [04/23/2009] OK.
C:\qrasp\QRTARW10.qrw
Date: [04/13/2007] *** Error; Needs: [12/21/2007]
Adagio Payables Status:
C:\qrasp\QRTAPW68.qrw
Date: [11/16/2009] OK.
C:\qrasp\QRTAPZ80.qrw
Date: [03/28/2007] *** Error; Needs: [12/21/2007]
C:\qrasp\QRTAPB68.qrw
Date: [10/20/2009] OK.
C:\qrasp\QRTAPT68.qrw
Date: [12/27/2002] *** Error; Needs: [10/15/2006]
C:\qrasp\QRTAPJ68.qrw
Date: [09/13/2004] *** Error; Needs: [10/15/2006]
Purchase Orders For Adagio Status:
C:\qrasp\QRTIR65A.qrw
Date: [05/16/2007] OK.
Adagio Receivables Status:
*** ERROR: Missing Report Table [C:\qrasp\QRTARB68.qrw]
*** ERROR: Missing Report Table [C:\qrasp\QRTARZ80.qrw]
*** ERROR: Missing Report Table [C:\qrasp\QRTARZ81.qrw]
C:\qrasp\QRTARW90.qrw
C:\qrasp\QRTARB90.qrw
Date: [12/16/2008] OK.
C:\qrasp\QRTARZ90.qrw
Date: [08/23/2010] OK.
C:\qrasp\QRTSMW90.qrw
Date: [11/05/2008] OK.
Adagio SalesAnalysis Status:
*** ERROR: Missing Report Table [C:\qrasp\QRTSRW68.qrw]
*** ERROR: Missing Report Table [C:\qrasp\QRTSRZ80.qrw]
C:\qrasp\QRTSRW90.qrw
Date: [06/21/2011] OK.
C:\qrasp\QRTSRZ90.qrw
Date: [10/14/2011] OK.
. . . . 28 Error(s) and 1 Warning(s) Reported.
================== Finished ===================
I know that the tables are missing - supposedly, but I'm not sure how to fix the issue.
Can I just open all of those ini files and point them to the new softrak installation directory? C:\softrak\system?
#31170 - 03/05/12 08:14 AM Re: Report table error [Re: Mach]
Bob Wisener Offline
Adagio Conductor
You could manually copy QRW tables, but it's better if the installs corrected the problem, with assistance from Softrak Support.
Bob Wisener
Dakota Software
#31173 - 03/05/12 08:36 AM Re: Report table error [Re: Bob Wisener]
Mach Offline
I don't understand though - I went through the installation and chose C:\ as my report tables - why didn't they get installed?
Either way, I'll contact Softrak Support to see what they say.
#31182 - 03/05/12 01:12 PM Re: Report table error [Re: Mach]
Your Report Table drive should be he same drive that Adagio is install on. FOr a network this is not normally drive C.
#31183 - 03/05/12 01:39 PM Re: Report table error [Re: Douglas Dickie]
Mach:
I would have mapped K: on the terminal server and done a fresh installation to that drive letter, then copied over the data.
0 registered (), 172 Guests and 3 Spiders online.
14577 Topics
