#29144 - 09/30/11 10:08 AM
Re: Gridview Upgrade
[Re: Softrak Support]
Hello Susan, This Filter might run a little faster:
AND (
{Date} >= QUERYDATE("Enter START Date:", TODAY()),
{Date} <= QUERYDATE("Enter END Date:", TODAY()),
Left({Salesperson},5) =Left(QueryString("Enter LINDSY, KINGSN, LONDON", ""),5),
{Qty} <> 0,
{Amt} <> 0,
{Category} <> " BE",
{Category} <> " MC ",
{Category} <> "RCO",
{Category} <> "RCA",
{Category} <> " SH",
{Category} <> " ZZ",
{Type} = "L" // select item lines only, skipping taxes and Misc charges.
You could also make the data entry easier with a calculated column for the Salesperson (say "Region"), like this:
IF(UPPER(TRIM(QUERYSTRING("Enter D, K or L for LINDSY, KINGSN or LONDON","K")))="D","LINDSY ",
IF(UPPER(TRIM(QUERYSTRING("Enter D, K or L for LINDSY, KINGSN or LONDON","K")))="K","KINGSN ","LONDON "
// The default will be "LONDON"
also, if you want to make sure that you are only asked a specific QUERY() question once, include ",1" as the third parameter, like this:
IF(UPPER(TRIM(QUERYSTRING("Enter D, K or L for LINDSY, KINGSN or LONDON","K",1)))="D","LINDSY",
IF(UPPER(TRIM(QUERYSTRING("Enter D, K or L for LINDSY, KINGSN or LONDON","K",1)))="K","KINGSN","LONDON"
If you create the calculated column, then your Filter becomes:
AND (
{Salesperson}={Region},
{Qty} <> 0,
{Amt} <> 0,
Finally, to remove all the category tests, you might consider using the Inventory report group or one of the option fields to contain something identifiable for this collection of items.
#29147 - 09/30/11 10:19 AM
[Re: Retired_Guy]
Thanks! This is a great help.
#29168 - 09/30/11 07:11 PM
[Re: SusanTennier]
Hi Softrak Support,
I assume you are aware that the the repeating of query prompts also occurs when you try to print the view. The query prompts repeat but the view doesn't reload thankfully.
#29169 - 09/30/11 07:24 PM
[Re: SusanTennier]
Hello Susan,
You can control when a View is calculated by settings in the Definition (Edit | Definition) and by setting the Recalc order of the Workspace (File | Set Workspace recalc order).
I'm surprised you're actually printing the View, rather than sending it to Excel. Is there a reason for this process?
#29175 - 10/03/11 07:18 AM
[Re: Retired_Guy]
We print it and send it to our reps along with their pay cheques. No need to use excel.
"Set Workspace recalculator order" is greyed out. Anyway, no issues. It's just an annoyance, however, the report is working fine.
#29176 - 10/03/11 07:50 AM
[Re: SusanTennier]
Hi Susan,
There is only "an order" when there are multiple Views in a workspace. For a single View, you can control when it is refreshed under Edit | Definition.
Thanks for information.
1 registered (Tanya_Belanger),
139
Guests and
2
Spiders online. |
14672 Topics
