Previous Thread
Next Thread
Print Thread
#28760 09/02/11 12:28 PM
P
Casual
Casual
P Offline
I upgraded to OrderEntry V8.1D last night and followed all the defaults. When I went into order entry afterwards, it came up with an error saying the reports tables drive is set to C:\ and it should be F:. I have run the reports table utility on the F drive and it says its fine. I can't see any place where I can set that workstations settings from C to F.
Pat
PLane #28764 09/02/11 02:07 PM
Hi, Pat,
Sounds like you may have installed the program to your local workstation rather than to drive F: on the server, or that at some time the program was installed on drive C:
Look on your C: drive to see if there is a QRASP folder (c:\qrasp). If so, rename it and reinstall the upgrade to the F: drive.
P
Casual
Casual
P Offline
There wasn't a C:\qrasp file, so in order to get the workstation operable, I copied the qrasp file to the c: drive and now they can work on that station.
I was going to reinstall the upgrade again, but I had also installed the service pack. Will it affect anything to reinstall over a service pack?
PLane #28771 09/02/11 04:05 PM
B
B Offline
Hello:
There should not be a QRASP folder on your local computer. Tech Support asked you to check if one existed as a diagnostic step. If it had existed, that would have indicated that the recent installation was inadvertently done to C: rather than to F:. It looks as if that isn't the case though.
I would delete the C:\QRASP folder and then proceed with your plan to re-install the update. There is no problem to re-install even though you subsequently applied the Service Pack. Once that is done, you can reinstall the Service Pack again.
Let us know if that works for you.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 71 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
