Posts: 10,504 |
Version 9.0A involved a complete re-design of the Customer file, with the inclusion of multiple contacts and additional information fields. Reports were changed to make sure that there was a way to print the new information. Not printing (or storing) the phone numbers would have "broken" the rule, if any such rule existed (which it doesn't).
Posts: 22 |
Hi All, I have a different problem with the Adress Only report. We have 3 companies and each is set up with at Report Group code. When I call for a group individually some of the customers in that group are missing. I can't figure out what is different in those customers vs. the ones that do print out. Any clues?
Posts: 11,746 |
Hi, Linda,
When you next run the report, take note of one of the customers that shows on the report and the exact spelling/case of the Report Group they belong to.
Next, look at one of the customers you feel should be showing on the same report. Does the spelling/case of this customer's Report Group match that of the other customers?
If you want to ensure that Report Groups are always entered in the same manner (spelling/case), turn on the 'Verify Report Groups' option in the Company Profile, System Options tab.
Regards, Softrak Tech Support
Posts: 22 |
Thank you for the advice. I went through the whole database, checked all the customers, changed a few to 'trick' the system and still quite a few customers are missing. Also turned on the verify report group option. I changed the ones who are missing several times, type in the report group as well as chose it with the finder. I don't see anything different with those customers. They are all active as well. We will do a DIC today or tomorrow to see if errors show up.
Posts: 22 |
How stupit am I????? I am so sorry about this, the balance in the criteria was set at a fairly low amount so of course the current customers with a balance above that would not show up.
My profound apologies.
Posts: 11,746 |
Hi, Linda,
No problem. I'm glad you were able to determine the cause of the problem. We all live and learn.
Posts: 10,504 |
The answer's always obvious when you know what it is.
0 members (),
71
guests, and
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
