Is there any way to reset the POA day end after the Day End failed to complete (like there used to be in the old ACCPAC Plus OE)?. POA day end did not run; Datacare integrity check shows no errors. Thanks for any help you can provide.
Thanks very much for the IRGLOB fix. It worked great and now POA opens no problem. That's one of the things I like about this database - things like this can be fixed so easily once one knows what to do. I really appreciate your help. Thanks again. Ed
#24672 - 10/27/1004:26 AMRe: Recovering from failed POA day end
[Re: EdW]
Steve Schwartz
Hi Ed
Make sure to run Data Integrity Check on the PO database. Resetting the IRGLOB status is nice, but it won't fix the underlying problem, if there is one. Only DIC can do that.
