#23651 - 08/18/10 08:28 AM Grid View How to insert a field from another table
chinmook Offline
Edward Chris Chin-Mook
Loc: Jamaica
Hi Guys,
Doing a GV and need to incorporate a field from a linked or joined Table. I have grouped my invoice line items by category, but I need to display the category description instead of the category numbers to make the report complete.
Help..
Edward C Chin-Mook
876-754-7444
876-754-5513
#23654 - 08/18/10 09:05 AM Re: Grid View How to insert a field from another table [Re: chinmook]
Hello Edward,
You can't current;y do that without our assistance. You need a composite table that links the OELINE to the IC Category file. Are you generating this report of the current or historical order entry file?
#23657 - 08/18/10 09:16 AM Re: Grid View How to insert a field from another table [Re: Retired_Guy]
If all you want to do is have a category description, it is possible to use a Named Items file in order to provide the 'Translation'. You could enter them manually via the Named Items function, and then use a Calculated Column to display the descriptions.
#23665 - 08/18/10 10:49 AM Re: Grid View How to insert a field from another table [Re: chinmook]
chinmook Offline
Loc: Jamaica
I am linking Adagio Invoices - Q/I History Detail Master table.
This is a report which has to be re-produced on the fly ((many many times)) can not ask clients to key in the Category Description.
Edward C Chin-Mook
876-754-7444
876-754-5513
#23667 - 08/18/10 10:58 AM Re: Grid View How to insert a field from another table [Re: chinmook]
Hello Edward,
How many Categories does the database have? How often are new Categories added?
Read about the =GETNAMEDITEM() function and create a list of the form (in a file or through the define Named items menu choice):
[NamedItems]
ABC=Category Description 1
DEF=Category Description 2
and then use the calculated column =GETNAMEDITEM({Item Category}).
#23670 - 08/18/10 11:28 AM Re: Grid View How to insert a field from another table [Re: Softrak Support]
chinmook Offline
Loc: Jamaica
Can you send me some details on how to connect the named items file- fields to my workspace.
What I did was put category code and description.
Calculated Worksheet is where I am coming up on the challenge.
Reading the manual again
Edward C Chin-Mook
876-754-7444
876-754-5513
#23671 - 08/18/10 11:39 AM Re: Grid View How to insert a field from another table [Re: chinmook]
The file containing the "named items" can be specified on the command line ("/n parameter") or in the defaults dialog.
#23676 - 08/19/10 06:45 AM Re: Grid View How to insert a field from another table [Re: Retired_Guy]
chinmook Offline
Loc: Jamaica
Andrew can you send me a demo gv using the function in a calculated column. Just can not seem to get it to work. ((This one has stumped me.))
Edward C Chin-Mook
876-754-7444
876-754-5513
#23691 - 08/19/10 01:26 PM Re: Grid View How to insert a field from another table [Re: chinmook]
Hello Edward,
Here is a ZIP contianing a GV workspace and an Excel spreadsheet to show you how this works. Here's what you need to know:
  • There are two Views in the workspace, one showing IN history detail lines that contain a Category, and a simple "DUMP" of the IC Category file. The history detail lines have a formula that displays a category description using the GETNAMEDITEM() function and selects only those lines that actually contain a category code.
  • You need to create a file of the form of CatList.GVNames. An easy way to do this is to ExcelDirect the Category View, Copy the third column (Headed "[NamedItems]") and paste it into a text file with a GVNames extension. Load this file into your GridView workspace using Edit | Named Items (F3). (Its name can be specified on the command line so the user does not have to remember to do this using the "/N" parameter).
  • Maintain as necessary.
Hopefully you can figure this out from the building blocks provided here.
NameListDemo.zip (111 downloads)
Edited by Andrew Bates (08/19/10 03:43 PM)
Edit Reason: Improved Workspace
#23697 - 08/19/10 07:06 PM Re: Grid View How to insert a field from another table [Re: Retired_Guy]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
Hi Edward,
Just a few notes:
<1> I'm not quite sure why he did it, but I don't believe that the "Cat" prefix that Andrew used in the actual list in the NamedItems text file "CatList.GVNames" in his demo example is "required". Now don't get me wrong, it is required due to the way he has configured the demo, I just did not want you to think that the prefix was a requirement in all uses of this function. Not that you would have thought that but some might.
<2> You'll definitely want to use the /n parameter but bear in mind that updating the text file and refreshing the loaded list during a GV session will not be totally automatic/dynamic so the users may need to be aware of this.
<3> Because of item <2> the questions raised above as to how often the IC categories have to be updated/maintained would be quite important to the effectiveness of the solution
Pete
Peter Banfield
BAMPH Consulting Services
Barbados
2 registered (Softrak Support, 1 invisible), 282 Guests and 3 Spiders online.
