Previous Thread
Next Thread
Print Thread
EdW
Offline
OE 81C. The OE Special Prices report will not preview or print, or show on screen. No error message displays; "Printing Report" briefly displays, but unlike the other file reports which do generate an actual report, this one just goes back to the report selection options screen.
ed@cascadiasystems.ca
Langley BC
Hi Ed
Go to the \Softrak\OEWIN folder. Is there a folder below that called ModRP? If there is, what files does it contain?
If there isn't, then click on the StandardRP folder. What's the date for the file oespeci1b.rpt? It should be 11/30/2009 12:39PM. Is the file name all in lower case letters?
Once you answer these questions, I can give you better advice.
Hi, Ed,
Steve's suggestions are valid.
However, you didn't indicate the specific release date of OE8.1C your are using. If you don't have a ModRP folder with this file in it and if your report date is correct within the StandardRP folder, it may be that you require a Hotfix to resolve the problem. The release date for the Hotfix is (100208). If this is the case, please contact your dealer and they will be able to provide you with this.
EdW
Offline
You're right, I need the HF. Problem actually is installing the HF (or any Adagio HF). Posted tonight on the 404 Not Found error and HF install failure.
Langley BC
EdW
Offline
Installed the HF. 404 error resolved: Don't change the HF file name (especially rename longer) and the install should work fine.
Langley BC
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 77 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
