#19141 - 10/19/09 01:49 PM Financial Reporter
ltribe Offline
Adagio Graduate
Loc: Kelowna BC
Creating a 3 year financial report. What is the function for 2 years ago, 3 years ago.
#19142 - 10/19/09 01:58 PM Re: Financial Reporter [Re: ltribe]
Hi, Lynn,
Look in the online Help 'index' under Formulas. There is an entire section on multiple years complete with examples.
For example, if the .ColSpec data token is Y, entering {1} immediately before the Y, will return the amount one year ago. You can go back 9 years and forward one year (eg. {-1}. It's important you use the squiggle brackets.
#19143 - 10/19/09 02:11 PM Re: Financial Reporter [Re: Softrak Support]
They're called brace brackets. The others are square brackets [] and parentheses (). wink
#19144 - 10/19/09 03:10 PM Re: Financial Reporter [Re: ltribe]
ltribe Offline
Adagio Graduate
Loc: Kelowna BC
ON line help index - please provide link - I could not find it
#19145 - 10/19/09 03:27 PM Re: Financial Reporter [Re: ltribe]
Press F1 in the financial reporter to launch the help.
#19146 - 10/19/09 03:28 PM Re: Financial Reporter [Re: ltribe]
Hi, Lynn,
When you're in the Financial Reporter, from the menu select Help | Contents. Click on the 'Show' button in the upper left of the toolbar and select the Index tab. Scroll or search to 'Formulas'.
#20096 - 12/17/09 02:56 PM Re: Financial Reporter [Re: Softrak Support]
ltribe Offline
Adagio Graduate
Loc: Kelowna BC
I can't find on line help index?
#20100 - 12/17/09 03:30 PM Re: Financial Reporter [Re: ltribe]
What version of Ledger and Financial Reporter? It may be that the path to locate the Financial Report help file in your Windows Registry is incorrect, or perhaps you don't have a copy of the financial reporter help saved to your local workstation.
Look for the file LedgerFinRep.chm in Windows Explorer on your local workstation if you want to load it 'manually'.
#20101 - 12/17/09 04:07 PM Re: Financial Reporter [Re: Softrak Support]
Michael Mulrooney Offline
This from the LedgerFinRep.chm
Multiple Years
Adagio's Financial Reporter enables you to report on up to 10 years of stored ledger data using both .ColSpec reports and Adagio Database functions.
To do so using ColSpec reports, simply edit the appropriate .ColSpec cell and prefix the code with {n}. {n} can be an integer from -9 to 9.
For example, if the .ColSpec account data token is Y:
editing the cell to read {1}Y will return the information for one year before the year displayed in the Year dropdown on the toolbar,
editing the cell to read {2}Y will return the information for two years before the year displayed in the Year dropdown on the toolbar,
editing the cell to read {-1}Y will return the information for one year in the future, after the year displayed in the Year dropdown on the toolbar.
To do so using Adagio Database formulas (eg. ADGET), again assume the account data token is Y, simply edit the formula as follows:
to read {1}Y (eg. =ADGET("gldata.{1}Y","$B11") will return the information for one year before the year displayed in the Year dropdown on the toolbar,
to read {2}Y (eg. =ADGET("gldata.{2}Y","$B11") will return the information for two years before the year displayed in the Year dropdown on the toolbar,
to read {-1}Y (eg. =ADGET("gldata.{-1}Y","$B11") will return the information for one year in the future, after the year displayed in the Year dropdown on the toolbar.
Again, {n} can be an integer from -9 to 9.
#20113 - 12/21/09 09:04 AM Adagio FX - With QB [Re: Michael Mulrooney]
Offline
Stranger
Loc: Nova Scotia, Canada
I am working through my first reports with Adagio FX and QuickBooks. No problem in getting the current year's numbers to agree with QB, but prior year numbers do not add up. Suggestions on what to check on in prior year numbers?
0 registered (), 169 Guests and 2 Spiders online.
14599 Topics
