#15128 - 11/18/08 01:16 PM
Inventory 8.1A "adjustment reason"
Doug Parrington
Loc: Winnipeg
Before upgrading to 8.1A, I was able to print out the "reason" we enter on every Inventory adjustment we did. Since then the crystal report I am using gives me no information after the upgrade. Where can I find the "reason" column in the database to get the information after the upgrade? I have tried in the ICW81 Adjustment Audit List, but that only keep the information for the current day.
Doug
#15130 - 11/18/08 02:19 PM
Re: Inventory 8.1A "adjustment reason"
[Re: doug]
Hi Doug,
Is this a customized Crystal Report that prints adjustments prior to posting? Or on the audit list file after posting? Or the Transaction History file?
As far as I can find, the report tables never looked at the pre-posted IC transactions, whether this was for Adjustments, Shipments or Stock Transfers. It only ever read the respective Audit List files, which get written to after posting. Adagio IC version 81A uses different files for storing the audit list information, and the IC81A report table is required for reports that work on the audit list files. I see that the Reason field works when using this file.
In Adagio IC 81A, you do not have to print and purge the audit lists in order to get the information into Transaction History - posting the adjustment (or other transaction types) writes directly to history. This means that you don't have to be in a hurry to purge audit lists anymore, as you used to have to do in versions 8.0A or older.
The Transactions History file does not store the Reason information, neither in the old version nor in 81A. It appears that the only place to get the Reason in a Crystal Report is the audit list file.
If you have Adagio GridView, this can read the Adjustment file before transactions are posted. And the Reason is properly displayed.
Regards, Softrak Tech Support
#15133 - 11/18/08 03:01 PM
[Re: Softrak Support]
Doug Parrington
Loc: Winnipeg
This is a customized Crystal Report that was looking at the Feild: "ICW65Adjustments.Reason" I can still run this report and see all the reasons going back to 1999 up until the update was done, after which there are no more adjustments saved in this table (because 81A uses different files).
I can read this information from the Adjustment file before transactions are posted, but I want to go back and generate reports several months and in some cases, years. I can see the adjustmens using the Transaction History but not the "Reason".
I was hoping then information was still stored like in the previous version, and I just needed to find it.
#15137 - 11/18/08 03:43 PM
Doug Parrington
Loc: Winnipeg
I am in the process of writing a new report using the ICW81 table, but I can not find the "Reason" in any of the tables. I have gone through all the ICW81 files using Crystal Reports and still can't find it. The only place I can find it is in the ICW65Adjustments and that only has the old data. Am I looking in the wrong Place?
Doug PS. thanks for the speedy replys
#15140 - 11/18/08 04:38 PM
Doug Parrington
Loc: Winnipeg
That is what I have done. I am using Field: ICW81 Adjustment Audit List.Reason but it only shows me todays Adjustments, and I need to go back to last month to get the reasons that were entered.
Thanks Doug
#15142 - 11/18/08 05:32 PM
Doug Parrington
Loc: Winnipeg
I sort of understand what you are saying, I have made several sub-reports before, but I'm not sure that will solve my problem. I can see my "Reasons" before April 2008 (upgrade date) and for today, but I can't find the "Reasons" in-between April and Today. I don't know where the "Reasons" have been stored (or if they are being stored) in Inventory 8.1A
Doug
0 registered (),
256
Guests and
Spider online. |
14668 Topics
