Posts: 93 |
Hello All,
I was curious if the possibility exists to create a departmental mask which includes departments which are not necessarily within a wildcardable range, eg. 116,655,902. I notice that the field for the mask only lets you input so many characters. Any ideas would be greatly appreciated!
Darcy Chretien
Posts: 11,750 |
Hi Darcy,
You can create department ranges of consecutive departments (say 100:199) or department masks that utilize a commonality in the department coding scheme (such as ?00 to get all 3-digit departments ending with '00'), but there is no facility to design customized non-concurrent wild-card ranges.
To get what you want in the easiest way, you can create a new financial statement using the 'drag-and-drop' method from the View Account Group screen. Select the 'Departmental Comparative' checkbox, and then select the desired departments and the 'Sum selected departments' option. This will create a spreadsheet with a number of columns, and that 'Sum Selected departments' column will contain your range of non-contiguous departments. Use the 'Hide when Printed' format on all the other columns so that they don't print - only the summed column will print.
Regards, Softrak Tech Support
Posts: 3,692 |
Hello Darcy:
Another option is the function RNGMERGE(). It allows you to specify a list of non-contiguous Departments. We have one client creating very complex reports with this feature.
See the sample statement GL!DeptRngMerge.sam and look at the 2 right-hand columns.
Posts: 93 |
Hi Bruce,
Thanks for the great idea, I will definitely have a look at that one.
Darcy Chretien
Posts: 10,504 |
Hi Darcy,
If you take Tech Support's suggestion and create a drag-and-drop departmental comparative, you'll see that it uses the =RNGMERGE() function to generate the column for the departments you have selected.
It's a fast way to generate a model.
Posts: 93 |
Andrew,
Thanks for the follow-up, I did use tech support's suggestion on the departmental comparative. I actually did see that it uses the =RNGMERGE()function, which was perfect.
Thanks guys!
Darcy Chretien
1 members (Softrak Support),
56
guests, and
robots. |
Forums5
Topics14,679
Posts71,629
Members1,874
S |
M |
T |
W |
T |
F |
S |
